Run Time: 0.000674
Run Time: 0.000176
WHERE (`xf_thread`.`thread_id` = '25722')
Run Time: 0.000937
WHERE (`xf_post`.`thread_id` = 25722) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002860
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 11 | Using where; Using filesort |
Params: 25722
Run Time: 0.000064
Params: 0, v~
Run Time: 0.000104
Params: v~, XF\Pub\Controller\Thread, Index, valid, thread_id=25722, 1716035437, , 0, v~
Run Time: 0.000092
WHERE (`xf_session_activity`.`user_id` = 27744) AND (`xf_session_activity`.`unique_key` = '27744')
Run Time: 0.000188
WHERE (`xf_thread_reply_ban`.`thread_id` = 25722) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000221
Run Time: 0.000211
bytes_sent | 9840 |
bytes_received | 288268 |
packets_sent | 112 |
packets_received | 876 |
protocol_overhead_in | 3504 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 233489 |
packets_sent_command | 55 |
packets_received_change_user | 88 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 72 |
rows_buffered_from_client_ps | 72 |
rows_skipped_ps | 72 |
proto_binary_fetched_bit | 151 |
proto_binary_fetched_short | 206 |
proto_binary_fetched_int24 | 84 |
proto_binary_fetched_bigint | 545 |
proto_binary_fetched_json | 443 |
proto_binary_fetched_blob | 217 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 232018 |
