Run Time: 0.000639
Run Time: 0.000230
WHERE (`xf_thread`.`thread_id` = '22194')
Run Time: 0.000799
WHERE (`xf_post`.`thread_id` = 22194) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004566
Params: 22194
Run Time: 0.000098
Params: 0, I
Run Time: 0.000153
Params: I, XF\Pub\Controller\Thread, Index, valid, thread_id=22194, 1714304868, , 0, I
Run Time: 0.000144
WHERE (`xf_session_activity`.`user_id` = 14329) AND (`xf_session_activity`.`unique_key` = '14329')
Run Time: 0.000202
Run Time: 0.000225
bytes_sent | 9344 |
bytes_received | 351004 |
packets_sent | 100 |
packets_received | 840 |
protocol_overhead_in | 3360 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 155 |
bytes_received_prepare_response_packet | 51818 |
bytes_received_change_user_packet | 298295 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 676 |
packets_received_change_user | 94 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 254 |
proto_binary_fetched_short | 359 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 620 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 296343 |
