Run Time: 0.000698
Run Time: 0.000202
WHERE (`xf_thread`.`thread_id` = '26082')
Run Time: 0.000767
WHERE (`xf_post`.`thread_id` = 26082) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003721
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 30 | Using index condition; Using where; Using filesort |
Params: 26082
Run Time: 0.000086
Params: 0,
Run Time: 0.000149
WHERE (`xf_session_activity`.`user_id` = 21543) AND (`xf_session_activity`.`unique_key` = '21543')
Run Time: 0.000172
WHERE (`xf_thread_reply_ban`.`thread_id` = 26082) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000206
Run Time: 0.000232
bytes_sent | 9438 |
bytes_received | 343646 |
packets_sent | 106 |
packets_received | 873 |
protocol_overhead_in | 3492 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 289187 |
packets_sent_command | 52 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 261 |
proto_binary_fetched_short | 359 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 287184 |
