Run Time: 0.000519
Run Time: 0.000208
WHERE (`xf_thread`.`thread_id` = '41035')
Run Time: 0.000845
WHERE (`xf_post`.`thread_id` = 41035) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003562
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (652882, 653283, 653284, 653285, 653453, 653454, 653557, 653664, 653781, 653782))
Run Time: 0.001394
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 25 | Using index condition; Using filesort |
Params: 41035
Run Time: 0.000094
Params: 0,
Run Time: 0.000128
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=41035, 1715364058, , 0,
Run Time: 0.000086
WHERE (`xf_thread_reply_ban`.`thread_id` = 41035) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000161
Run Time: 0.000197
bytes_sent | 11969 |
bytes_received | 348545 |
packets_sent | 112 |
packets_received | 1059 |
protocol_overhead_in | 4236 |
protocol_overhead_out | 448 |
bytes_received_prepare_response_packet | 69392 |
bytes_received_change_user_packet | 278215 |
packets_sent_command | 55 |
packets_received_prepare_response | 856 |
packets_received_change_user | 125 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 109 |
rows_buffered_from_client_ps | 109 |
rows_skipped_ps | 109 |
proto_binary_fetched_bit | 1618 |
proto_binary_fetched_short | 410 |
proto_binary_fetched_bigint | 1317 |
proto_binary_fetched_decimal | 48 |
proto_binary_fetched_json | 887 |
proto_binary_fetched_blob | 362 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 275573 |
