Run Time: 0.000352
Run Time: 0.000152
WHERE (`xf_thread`.`thread_id` = '43235')
Run Time: 0.000496
WHERE (`xf_post`.`thread_id` = 43235) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001050
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 4 | Using where; Using filesort |
Params: 43235
Run Time: 0.000077
Params: 0, ܺ0
Run Time: 0.000113
Params: ܺ0, XF\Pub\Controller\Thread, Index, valid, thread_id=43235, 1717075473, , 0, ܺ0
Run Time: 0.000103
WHERE (`xf_session_activity`.`user_id` = 46686) AND (`xf_session_activity`.`unique_key` = '46686')
Run Time: 0.000141
WHERE (`xf_thread_reply_ban`.`thread_id` = 43235) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000159
Run Time: 0.000159
bytes_sent | 9840 |
bytes_received | 247434 |
packets_sent | 112 |
packets_received | 869 |
protocol_overhead_in | 3476 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 192655 |
packets_sent_command | 55 |
packets_received_change_user | 81 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 65 |
rows_buffered_from_client_ps | 65 |
rows_skipped_ps | 65 |
proto_binary_fetched_bit | 67 |
proto_binary_fetched_short | 87 |
proto_binary_fetched_int24 | 35 |
proto_binary_fetched_bigint | 237 |
proto_binary_fetched_json | 303 |
proto_binary_fetched_blob | 112 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 191621 |
