Run Time: 0.000408
Run Time: 0.000206
WHERE (`xf_thread`.`thread_id` = '33481')
Run Time: 0.000817
WHERE (`xf_post`.`thread_id` = 33481) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003344
Params: 33481
Run Time: 0.000102
Params: 0, ܌
Run Time: 0.000213
Params: ܌, XF\Pub\Controller\Thread, Index, valid, thread_id=33481, 1714298277, , 0, ܌
Run Time: 0.000212
WHERE (`xf_session_activity`.`user_id` = 14174) AND (`xf_session_activity`.`unique_key` = '14174')
Run Time: 0.000237
WHERE (`xf_thread_reply_ban`.`thread_id` = 33481) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000204
Run Time: 0.000194
bytes_sent | 9840 |
bytes_received | 341713 |
packets_sent | 112 |
packets_received | 885 |
protocol_overhead_in | 3540 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 286934 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 257 |
proto_binary_fetched_short | 361 |
proto_binary_fetched_blob | 354 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 284903 |
