Run Time: 0.000425
Run Time: 0.000209
WHERE (`xf_thread`.`thread_id` = '2334')
Run Time: 0.000803
WHERE (`xf_post`.`thread_id` = 2334) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005283
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (16763, 16821, 16885, 16955, 17016, 17029, 17083))
Run Time: 0.001702
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 7 | Using index condition; Using filesort |
Params: 2334
Run Time: 0.000101
Params: 0,
Run Time: 0.000161
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=2334, 1716547583, , 0,
Run Time: 0.000146
WHERE (`xf_session_activity`.`user_id` = 1573) AND (`xf_session_activity`.`unique_key` = '1573')
Run Time: 0.000214
Run Time: 0.000218
bytes_sent | 11880 |
bytes_received | 351739 |
packets_sent | 112 |
packets_received | 1046 |
protocol_overhead_in | 4184 |
protocol_overhead_out | 448 |
bytes_received_prepare_response_packet | 69752 |
bytes_received_change_user_packet | 281008 |
packets_sent_command | 55 |
packets_received_prepare_response | 860 |
packets_received_change_user | 108 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 92 |
rows_buffered_from_client_ps | 92 |
rows_skipped_ps | 92 |
proto_binary_fetched_bit | 668 |
proto_binary_fetched_short | 373 |
proto_binary_fetched_bigint | 1038 |
proto_binary_fetched_decimal | 30 |
proto_binary_fetched_json | 699 |
proto_binary_fetched_blob | 359 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 278821 |
