Run Time: 0.000767
Run Time: 0.000242
WHERE (`xf_thread`.`thread_id` = '19237')
Run Time: 0.000856
WHERE (`xf_post`.`thread_id` = 19237) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005561
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (239621, 241081, 242217, 242704, 243228, 243805, 244296, 245942))
Run Time: 0.001919
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 9 | Using index condition; Using filesort |
Params: 19237
Run Time: 0.000096
Params: 0,
Run Time: 0.000144
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=19237, 1714611763, , 0,
Run Time: 0.000107
WHERE (`xf_session_activity`.`user_id` = 15675) AND (`xf_session_activity`.`unique_key` = '15675')
Run Time: 0.000244
WHERE (`xf_thread_reply_ban`.`thread_id` = 19237) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000249
Run Time: 0.000220
bytes_sent | 12423 |
bytes_received | 354628 |
packets_sent | 124 |
packets_received | 1093 |
protocol_overhead_in | 4372 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 281868 |
packets_sent_command | 61 |
packets_received_change_user | 113 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 95 |
rows_buffered_from_client_ps | 95 |
rows_skipped_ps | 95 |
proto_binary_fetched_bit | 789 |
proto_binary_fetched_short | 381 |
proto_binary_fetched_bigint | 1067 |
proto_binary_fetched_decimal | 33 |
proto_binary_fetched_json | 711 |
proto_binary_fetched_blob | 360 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 279591 |
