Nikon DSLR Cameras
D7100
Urgent help please
<blockquote data-quote="WayneF" data-source="post: 444408" data-attributes="member: 12496"><p>It could have been Auto FP then (menu E1). Reset Custom resets it Off. Auto FP allows the TTL SB-700 to do HSS flash (shutter speed faster than maximum sync speed), which reduces its power capability to about 20% of speedlight power (which might be insufficient). In Auto FP mode, changing shutter to be above 1/250 second (anything faster) will cause that reduction. </p><p></p><p>But manual camera mode should not have allowed shutter speed to change from what you set it to be (unless Auto ISO was a factor).</p></blockquote><p></p>
[QUOTE="WayneF, post: 444408, member: 12496"] It could have been Auto FP then (menu E1). Reset Custom resets it Off. Auto FP allows the TTL SB-700 to do HSS flash (shutter speed faster than maximum sync speed), which reduces its power capability to about 20% of speedlight power (which might be insufficient). In Auto FP mode, changing shutter to be above 1/250 second (anything faster) will cause that reduction. But manual camera mode should not have allowed shutter speed to change from what you set it to be (unless Auto ISO was a factor). [/QUOTE]
Nikon DSLR Cameras
D7100
Urgent help please
