Run Time: 0.000744
Run Time: 0.000201
WHERE (`xf_thread`.`thread_id` = '25640')
Run Time: 0.001202
WHERE (`xf_post`.`thread_id` = 25640) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003596
Params: 25640
Run Time: 0.000108
Params: 0,
Run Time: 0.000146
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=25640, 1715962494, , 0,
Run Time: 0.000107
WHERE (`xf_session_activity`.`user_id` = 14717) AND (`xf_session_activity`.`unique_key` = '14717')
Run Time: 0.000178
WHERE (`xf_thread_reply_ban`.`thread_id` = 25640) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000183
Run Time: 0.000186
bytes_sent | 9853 |
bytes_received | 340729 |
packets_sent | 112 |
packets_received | 884 |
protocol_overhead_in | 3536 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 285991 |
packets_sent_command | 55 |
packets_received_change_user | 96 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 260 |
proto_binary_fetched_short | 359 |
proto_binary_fetched_bigint | 939 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 283983 |
