Other Photography Equipment
Tripod Help
<blockquote data-quote="Blade Canyon" data-source="post: 500086" data-attributes="member: 15302"><p>My one caveat about getting a used one is that the devices that lock the legs in the extended position sometimes wear out over time, and the leg will slowly slide back in, making the tripod unstable. I had a good telescope tripod that failed in that very way and the telescope hit the garage floor hard.</p><p></p><p>Good luck with fixing yours, but if you decide to buy one I also like Manfrotto.</p></blockquote><p></p>
[QUOTE="Blade Canyon, post: 500086, member: 15302"] My one caveat about getting a used one is that the devices that lock the legs in the extended position sometimes wear out over time, and the leg will slowly slide back in, making the tripod unstable. I had a good telescope tripod that failed in that very way and the telescope hit the garage floor hard. Good luck with fixing yours, but if you decide to buy one I also like Manfrotto. [/QUOTE]
Tripod Help
