Run Time: 0.000685
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '43389')
Run Time: 0.000847
WHERE (`xf_post`.`thread_id` = 43389) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002262
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 11 | Using where; Using filesort |
Params: 43389
Run Time: 0.000110
Params: 0, ݸH
Run Time: 0.000198
Params: ݸH, XF\Pub\Controller\Thread, Index, valid, thread_id=43389, 1716756349, , 0, ݸH
Run Time: 0.000197
WHERE (`xf_session_activity`.`user_id` = 46859) AND (`xf_session_activity`.`unique_key` = '46859')
Run Time: 0.000183
WHERE (`xf_thread_reply_ban`.`thread_id` = 43389) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000231
Run Time: 0.000235
bytes_sent | 9840 |
bytes_received | 287135 |
packets_sent | 112 |
packets_received | 876 |
protocol_overhead_in | 3504 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 232356 |
packets_sent_command | 55 |
packets_received_change_user | 88 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 72 |
rows_buffered_from_client_ps | 72 |
rows_skipped_ps | 72 |
proto_binary_fetched_bit | 128 |
proto_binary_fetched_short | 211 |
proto_binary_fetched_int24 | 84 |
proto_binary_fetched_bigint | 548 |
proto_binary_fetched_json | 457 |
proto_binary_fetched_blob | 218 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 230878 |
