Run Time: 0.000752
Run Time: 0.000209
WHERE (`xf_thread`.`thread_id` = '21942')
Run Time: 0.000765
WHERE (`xf_post`.`thread_id` = 21942) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004454
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (291254, 292208, 292213, 293022, 293023, 293025, 293027))
Run Time: 0.002347
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 20 | Using index condition; Using filesort |
Params: 21942
Run Time: 0.000091
Params: 0,
Run Time: 0.000157
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=21942, 1716016554, , 0,
Run Time: 0.000145
WHERE (`xf_session_activity`.`user_id` = 9701) AND (`xf_session_activity`.`unique_key` = '9701')
Run Time: 0.000174
WHERE (`xf_thread_reply_ban`.`thread_id` = 21942) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000218
Run Time: 0.000276
bytes_sent | 12396 |
bytes_received | 360441 |
packets_sent | 124 |
packets_received | 1104 |
protocol_overhead_in | 4416 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 287640 |
packets_sent_command | 61 |
packets_received_change_user | 124 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 106 |
rows_buffered_from_client_ps | 106 |
rows_skipped_ps | 106 |
proto_binary_fetched_bit | 1454 |
proto_binary_fetched_short | 400 |
proto_binary_fetched_bigint | 1220 |
proto_binary_fetched_decimal | 44 |
proto_binary_fetched_json | 766 |
proto_binary_fetched_blob | 359 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 285123 |
