Run Time: 0.000918
Run Time: 0.000189
WHERE (`xf_thread`.`thread_id` = '45240')
Run Time: 0.000930
WHERE (`xf_post`.`thread_id` = 45240) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002533
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 13 | Using where; Using filesort |
Params: 45240
Run Time: 0.000137
Params: 0, ;=e
Run Time: 0.000142
Params: ;=e, XF\Pub\Controller\Thread, Index, valid, thread_id=45240, 1717115944, , 0, ;=e
Run Time: 0.000133
WHERE (`xf_session_activity`.`user_id` = 34269) AND (`xf_session_activity`.`unique_key` = '34269')
Run Time: 0.000209
WHERE (`xf_thread_reply_ban`.`thread_id` = 45240) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000190
Run Time: 0.000218
bytes_sent | 9840 |
bytes_received | 300956 |
packets_sent | 112 |
packets_received | 878 |
protocol_overhead_in | 3512 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 246177 |
packets_sent_command | 55 |
packets_received_change_user | 90 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 74 |
rows_buffered_from_client_ps | 74 |
rows_skipped_ps | 74 |
proto_binary_fetched_bit | 174 |
proto_binary_fetched_short | 242 |
proto_binary_fetched_int24 | 98 |
proto_binary_fetched_bigint | 632 |
proto_binary_fetched_json | 483 |
proto_binary_fetched_blob | 247 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 244596 |
