Nikon DSLR Cameras
D3200
Shadow on photograph when using 16mm Wide Angle Lens
<blockquote data-quote="aroy" data-source="post: 569987" data-attributes="member: 16090"><p>The internal flash is set quite low, so with a lens+hood beyond a certain diameter will interfere with the flash. Your only recourse is to either shoot without a flash or use an external flash gun mounted on the hot shoe (with some long lenses this will also interfere for close shots).</p></blockquote><p></p>
[QUOTE="aroy, post: 569987, member: 16090"] The internal flash is set quite low, so with a lens+hood beyond a certain diameter will interfere with the flash. Your only recourse is to either shoot without a flash or use an external flash gun mounted on the hot shoe (with some long lenses this will also interfere for close shots). [/QUOTE]
Nikon DSLR Cameras
D3200
