Run Time: 0.000717
Run Time: 0.000229
WHERE (`xf_thread`.`thread_id` = '31308')
Run Time: 0.000789
WHERE (`xf_post`.`thread_id` = 31308) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003974
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 19 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (466339, 466528, 466562))
Run Time: 0.001478
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 31308
Run Time: 0.000110
Params: 0,
Run Time: 0.000137
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=31308, 1716011450, , 0,
Run Time: 0.000125
WHERE (`xf_session_activity`.`user_id` = 10216) AND (`xf_session_activity`.`unique_key` = '10216')
Run Time: 0.000172
WHERE (`xf_thread_reply_ban`.`thread_id` = 31308) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000201
Run Time: 0.000198
bytes_sent | 12336 |
bytes_received | 338083 |
packets_sent | 124 |
packets_received | 1086 |
protocol_overhead_in | 4344 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 265282 |
packets_sent_command | 61 |
packets_received_change_user | 106 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 88 |
rows_buffered_from_client_ps | 88 |
rows_skipped_ps | 88 |
proto_binary_fetched_bit | 474 |
proto_binary_fetched_short | 333 |
proto_binary_fetched_int24 | 133 |
proto_binary_fetched_bigint | 908 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 647 |
proto_binary_fetched_blob | 325 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 263264 |
