Run Time: 0.000845
Run Time: 0.000143
WHERE (`xf_thread`.`thread_id` = '12476')
Run Time: 0.000651
WHERE (`xf_post`.`thread_id` = 12476) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001676
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 2 | Using where; Using filesort |
Params: 12476
Run Time: 0.000080
Params: 0,
Run Time: 0.000123
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=12476, 1714516480, , 0,
Run Time: 0.000082
WHERE (`xf_session_activity`.`user_id` = 10336) AND (`xf_session_activity`.`unique_key` = '10336')
Run Time: 0.000176
Run Time: 0.000210
bytes_sent | 9357 |
bytes_received | 230992 |
packets_sent | 100 |
packets_received | 821 |
protocol_overhead_in | 3284 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 114 |
bytes_received_prepare_response_packet | 51818 |
bytes_received_change_user_packet | 178324 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 676 |
packets_received_change_user | 75 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_fetched_from_server_ps | 61 |
rows_buffered_from_client_ps | 61 |
rows_skipped_ps | 61 |
proto_binary_fetched_bit | 37 |
proto_binary_fetched_short | 53 |
proto_binary_fetched_int24 | 21 |
proto_binary_fetched_bigint | 147 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 261 |
proto_binary_fetched_blob | 82 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 177437 |
