Run Time: 0.000692
Run Time: 0.000220
WHERE (`xf_thread`.`thread_id` = '19236')
Run Time: 0.000754
WHERE (`xf_post`.`thread_id` = 19236) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003715
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (239605, 242243, 242773, 242835, 243100, 243212, 249415, 254100, 254118, 254195))
Run Time: 0.001576
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 14 | Using index condition; Using filesort |
Params: 19236
Run Time: 0.000111
Params: 0,
Run Time: 0.000146
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=19236, 1714274427, , 0,
Run Time: 0.000110
WHERE (`xf_session_activity`.`user_id` = 9496) AND (`xf_session_activity`.`unique_key` = '9496')
Run Time: 0.000181
WHERE (`xf_thread_reply_ban`.`thread_id` = 19236) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000204
Run Time: 0.000225
bytes_sent | 12457 |
bytes_received | 356127 |
packets_sent | 124 |
packets_received | 1097 |
protocol_overhead_in | 4388 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 283367 |
packets_sent_command | 61 |
packets_received_change_user | 117 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 99 |
rows_buffered_from_client_ps | 99 |
rows_skipped_ps | 99 |
proto_binary_fetched_bit | 1089 |
proto_binary_fetched_short | 390 |
proto_binary_fetched_bigint | 1135 |
proto_binary_fetched_decimal | 38 |
proto_binary_fetched_json | 736 |
proto_binary_fetched_blob | 362 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 281009 |
