Run Time: 0.000628
Run Time: 0.000203
WHERE (`xf_thread`.`thread_id` = '27170')
Run Time: 0.000768
WHERE (`xf_post`.`thread_id` = 27170) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004697
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 16 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (384938, 386643, 387055, 418953, 422146))
Run Time: 0.002896
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 10 | Using index condition; Using filesort |
Params: 27170
Run Time: 0.000083
Params: 0, v!D
Run Time: 0.000183
Params: v!D, XF\Pub\Controller\Thread, Index, valid, thread_id=27170, 1716960724, , 0, v!D
Run Time: 0.000129
WHERE (`xf_session_activity`.`user_id` = 24753) AND (`xf_session_activity`.`unique_key` = '24753')
Run Time: 0.000183
WHERE (`xf_thread_reply_ban`.`thread_id` = 27170) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000220
Run Time: 0.000201
bytes_sent | 12368 |
bytes_received | 336382 |
packets_sent | 124 |
packets_received | 1090 |
protocol_overhead_in | 4360 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 263581 |
packets_sent_command | 61 |
packets_received_change_user | 110 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 92 |
rows_buffered_from_client_ps | 92 |
rows_skipped_ps | 92 |
proto_binary_fetched_bit | 808 |
proto_binary_fetched_short | 311 |
proto_binary_fetched_int24 | 119 |
proto_binary_fetched_bigint | 904 |
proto_binary_fetched_decimal | 34 |
proto_binary_fetched_json | 637 |
proto_binary_fetched_blob | 297 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 261537 |
