Run Time: 0.000711
Run Time: 0.000261
WHERE (`xf_thread`.`thread_id` = '7436')
Run Time: 0.000804
WHERE (`xf_post`.`thread_id` = 7436) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004257
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (71868, 71906, 72355, 72595, 72663, 72863, 72877, 73605, 76864, 76940, 77131, 78074, 78077, 78159))
Run Time: 0.001573
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 16 | Using index condition; Using filesort |
Params: 7436
Run Time: 0.000106
Params: 0,
Run Time: 0.000166
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=7436, 1714767848, , 0,
Run Time: 0.000154
WHERE (`xf_session_activity`.`user_id` = 9298) AND (`xf_session_activity`.`unique_key` = '9298')
Run Time: 0.000196
WHERE (`xf_thread_reply_ban`.`thread_id` = 7436) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000230
Run Time: 0.000218
bytes_sent | 12472 |
bytes_received | 358494 |
packets_sent | 124 |
packets_received | 1100 |
protocol_overhead_in | 4400 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 285693 |
packets_sent_command | 61 |
packets_received_change_user | 120 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 102 |
rows_buffered_from_client_ps | 102 |
rows_skipped_ps | 102 |
proto_binary_fetched_bit | 1200 |
proto_binary_fetched_short | 396 |
proto_binary_fetched_bigint | 1168 |
proto_binary_fetched_decimal | 40 |
proto_binary_fetched_json | 746 |
proto_binary_fetched_blob | 365 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 283276 |
