Run Time: 0.000640
Run Time: 0.000252
WHERE (`xf_thread`.`thread_id` = '30094')
Run Time: 0.000833
WHERE (`xf_post`.`thread_id` = 30094) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005894
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (441888, 442274, 442276, 445062, 452848, 463724, 479770, 480875, 482765, 482766, 485074, 488600, 489404))
Run Time: 0.005525
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 19 | Using index condition; Using filesort |
Params: 30094
Run Time: 0.000110
Params: 0,
Run Time: 0.000154
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=30094, 1715944384, , 0,
Run Time: 0.000138
WHERE (`xf_session_activity`.`user_id` = 37727) AND (`xf_session_activity`.`unique_key` = '37727')
Run Time: 0.000209
WHERE (`xf_thread_reply_ban`.`thread_id` = 30094) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000219
Run Time: 0.000217
bytes_sent | 12496 |
bytes_received | 352993 |
packets_sent | 124 |
packets_received | 1103 |
protocol_overhead_in | 4412 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 280192 |
packets_sent_command | 61 |
packets_received_change_user | 123 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 105 |
rows_buffered_from_client_ps | 105 |
rows_skipped_ps | 105 |
proto_binary_fetched_bit | 1359 |
proto_binary_fetched_short | 400 |
proto_binary_fetched_bigint | 1212 |
proto_binary_fetched_decimal | 43 |
proto_binary_fetched_json | 782 |
proto_binary_fetched_blob | 365 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 277695 |
