Run Time: 0.000667
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '2276')
Run Time: 0.000992
WHERE (`xf_post`.`thread_id` = 2276) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003033
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (16108, 16350, 16357))
Run Time: 0.001332
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 2276
Run Time: 0.000122
Params: 0, L
Run Time: 0.000185
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: L , XF\Pub\Controller\Thread, Index, valid, thread_id=2276, 1715341871, , 0, L
Run Time: 0.000118
WHERE (`xf_session_activity`.`user_id` = 165) AND (`xf_session_activity`.`unique_key` = '165')
Run Time: 0.000193
WHERE (`xf_thread_reply_ban`.`thread_id` = 2276) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000232
Run Time: 0.000217
bytes_sent | 12327 |
bytes_received | 348749 |
packets_sent | 124 |
packets_received | 1087 |
protocol_overhead_in | 4348 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 275989 |
packets_sent_command | 61 |
packets_received_change_user | 107 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 89 |
rows_buffered_from_client_ps | 89 |
rows_skipped_ps | 89 |
proto_binary_fetched_bit | 500 |
proto_binary_fetched_short | 367 |
proto_binary_fetched_bigint | 995 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 686 |
proto_binary_fetched_blob | 354 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 273853 |
