Run Time: 0.000716
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '15324')
Run Time: 0.000660
WHERE (`xf_post`.`thread_id` = 15324) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003391
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (177235))
Run Time: 0.000999
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 2 | Using index condition; Using where |
Params: 15324
Run Time: 0.000099
Params: 0, 8r
Run Time: 0.000169
Params: 8r, XF\Pub\Controller\Thread, Index, valid, thread_id=15324, 1714311223, , 0, 8r
Run Time: 0.000151
WHERE (`xf_session_activity`.`user_id` = 14162) AND (`xf_session_activity`.`unique_key` = '14162')
Run Time: 0.000173
WHERE (`xf_thread_reply_ban`.`thread_id` = 15324) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000222
Run Time: 0.000171
bytes_sent | 12304 |
bytes_received | 377004 |
packets_sent | 124 |
packets_received | 1086 |
protocol_overhead_in | 4344 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 304203 |
packets_sent_command | 61 |
packets_received_change_user | 106 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 88 |
rows_buffered_from_client_ps | 88 |
rows_skipped_ps | 88 |
proto_binary_fetched_bit | 380 |
proto_binary_fetched_short | 363 |
proto_binary_fetched_bigint | 968 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 677 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 302047 |
