Run Time: 0.000481
Run Time: 0.000211
WHERE (`xf_thread`.`thread_id` = '806')
Run Time: 0.000777
WHERE (`xf_post`.`thread_id` = 806) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002439
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 19 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (2592))
Run Time: 0.001216
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 3 | Using index condition; Using where |
Params: 806
Run Time: 0.000094
Params: 0, t
Run Time: 0.000208
Params: t, XF\Pub\Controller\Thread, Index, valid, thread_id=806, 1715918302, , 0, t
Run Time: 0.000179
WHERE (`xf_session_activity`.`user_id` = 636) AND (`xf_session_activity`.`unique_key` = '636')
Run Time: 0.000202
WHERE (`xf_thread_reply_ban`.`thread_id` = 806) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000214
Run Time: 0.000172
bytes_sent | 12276 |
bytes_received | 348844 |
packets_sent | 124 |
packets_received | 1085 |
protocol_overhead_in | 4340 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 276043 |
packets_sent_command | 61 |
packets_received_change_user | 105 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 87 |
rows_buffered_from_client_ps | 87 |
rows_skipped_ps | 87 |
proto_binary_fetched_bit | 415 |
proto_binary_fetched_short | 331 |
proto_binary_fetched_int24 | 133 |
proto_binary_fetched_bigint | 894 |
proto_binary_fetched_decimal | 27 |
proto_binary_fetched_json | 643 |
proto_binary_fetched_blob | 323 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 274025 |
