Lenses
Prime
Nikon AF Nikkor 50mm f1.8 D focusing problems
<blockquote data-quote="nickt" data-source="post: 473113" data-attributes="member: 4923"><p>But is that an AF lens? If it is an AF-S, the test doesn't show anything. The newer AF-S lenses have their own internal focus motor and do not use the camera drive. If you don't have another AF lens, my only suggestion is to try the small screwdriver to drive the lens as said above. It should be very easy to turn. If it is hard to spin or the effort changes at points, it is likely the lens. The 50mm is probably not worth having repaired, at least not by Nikon. The camera might be worth it. I don't know of any self-repairs.</p></blockquote><p></p>
[QUOTE="nickt, post: 473113, member: 4923"] But is that an AF lens? If it is an AF-S, the test doesn't show anything. The newer AF-S lenses have their own internal focus motor and do not use the camera drive. If you don't have another AF lens, my only suggestion is to try the small screwdriver to drive the lens as said above. It should be very easy to turn. If it is hard to spin or the effort changes at points, it is likely the lens. The 50mm is probably not worth having repaired, at least not by Nikon. The camera might be worth it. I don't know of any self-repairs. [/QUOTE]
Lenses
Prime
