Run Time: 0.000675
Run Time: 0.000210
WHERE (`xf_thread`.`thread_id` = '25')
Run Time: 0.000789
WHERE (`xf_post`.`thread_id` = 25) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001651
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 3 | Using where; Using filesort |
Params: 25
Run Time: 0.000098
Params: 0, ޔ|
Run Time: 0.000207
Params: ޔ|, XF\Pub\Controller\Thread, Index, valid, thread_id=25, 1714265931, , 0, ޔ|
Run Time: 0.000154
WHERE (`xf_session_activity`.`user_id` = 2) AND (`xf_session_activity`.`unique_key` = '2')
Run Time: 0.000229
WHERE (`xf_thread_reply_ban`.`thread_id` = 25) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000226
Run Time: 0.000224
bytes_sent | 9800 |
bytes_received | 238670 |
packets_sent | 112 |
packets_received | 868 |
protocol_overhead_in | 3472 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 183891 |
packets_sent_command | 55 |
packets_received_change_user | 80 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 64 |
rows_buffered_from_client_ps | 64 |
rows_skipped_ps | 64 |
proto_binary_fetched_bit | 54 |
proto_binary_fetched_short | 71 |
proto_binary_fetched_int24 | 28 |
proto_binary_fetched_bigint | 192 |
proto_binary_fetched_json | 283 |
proto_binary_fetched_blob | 98 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 182923 |
