Run Time: 0.000712
Run Time: 0.000241
WHERE (`xf_thread`.`thread_id` = '9582')
Run Time: 0.001031
WHERE (`xf_post`.`thread_id` = 9582) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002709
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
Params: 9582
Run Time: 0.000091
Params: 0, n:
Run Time: 0.000160
Params: n:, XF\Pub\Controller\Thread, Index, valid, thread_id=9582, 1716063095, , 0, n:
Run Time: 0.000151
WHERE (`xf_session_activity`.`user_id` = 12044) AND (`xf_session_activity`.`unique_key` = '12044')
Run Time: 0.000190
WHERE (`xf_thread_reply_ban`.`thread_id` = 9582) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000229
Run Time: 0.000219
bytes_sent | 9832 |
bytes_received | 262757 |
packets_sent | 112 |
packets_received | 872 |
protocol_overhead_in | 3488 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 207978 |
packets_sent_command | 55 |
packets_received_change_user | 84 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 68 |
rows_buffered_from_client_ps | 68 |
rows_skipped_ps | 68 |
proto_binary_fetched_bit | 104 |
proto_binary_fetched_short | 138 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 368 |
proto_binary_fetched_json | 363 |
proto_binary_fetched_blob | 157 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 206767 |
