Macro
Need advice for a possible macro lens.
<blockquote data-quote="nzswift" data-source="post: 445241" data-attributes="member: 9707"><p>A macro/micro lens also takes high quality general shots. Think about the focal length you most are most wanting/lacking and go for that. Another consideration is not to dismiss the old AI/AIS manual focus Nikon Micro lenses (with the appropriate extension rings is you want 1:1, (not often). AF is pretty much redundant in macro work and is you buy a AF lens you will probably find yourself using it in M mode... Will work fine on your D7000 too.</p></blockquote><p></p>
[QUOTE="nzswift, post: 445241, member: 9707"] A macro/micro lens also takes high quality general shots. Think about the focal length you most are most wanting/lacking and go for that. Another consideration is not to dismiss the old AI/AIS manual focus Nikon Micro lenses (with the appropriate extension rings is you want 1:1, (not often). AF is pretty much redundant in macro work and is you buy a AF lens you will probably find yourself using it in M mode... Will work fine on your D7000 too. [/QUOTE]
Macro
