Run Time: 0.000705
Run Time: 0.000205
WHERE (`xf_thread`.`thread_id` = '30006')
Run Time: 0.001098
WHERE (`xf_post`.`thread_id` = 30006) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004209
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (440367, 440425, 440447))
Run Time: 0.001348
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 18 | Using index condition; Using filesort |
Params: 30006
Run Time: 0.000093
Params: 0,
Run Time: 0.000161
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=30006, 1716063829, , 0,
Run Time: 0.000145
WHERE (`xf_session_activity`.`user_id` = 8344) AND (`xf_session_activity`.`unique_key` = '8344')
Run Time: 0.000207
WHERE (`xf_thread_reply_ban`.`thread_id` = 30006) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000225
Run Time: 0.000262
bytes_sent | 12332 |
bytes_received | 371655 |
packets_sent | 124 |
packets_received | 1102 |
protocol_overhead_in | 4408 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 298854 |
packets_sent_command | 61 |
packets_received_change_user | 122 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 104 |
rows_buffered_from_client_ps | 104 |
rows_skipped_ps | 104 |
proto_binary_fetched_bit | 1338 |
proto_binary_fetched_short | 396 |
proto_binary_fetched_bigint | 1192 |
proto_binary_fetched_decimal | 42 |
proto_binary_fetched_json | 756 |
proto_binary_fetched_blob | 355 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 296343 |
