Run Time: 0.000658
Run Time: 0.000211
WHERE (`xf_thread`.`thread_id` = '45857')
Run Time: 0.000772
WHERE (`xf_post`.`thread_id` = 45857) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002090
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (776846, 777157, 778498, 783966, 786987))
Run Time: 0.002946
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 7 | Using index condition; Using filesort |
Params: 45857
Run Time: 0.000109
Params: 0, t4
Run Time: 0.000143
Params: t4, XF\Pub\Controller\Thread, Index, valid, thread_id=45857, 1716219790, , 0, t4
Run Time: 0.000124
WHERE (`xf_session_activity`.`user_id` = 3903) AND (`xf_session_activity`.`unique_key` = '3903')
Run Time: 0.000180
WHERE (`xf_thread_reply_ban`.`thread_id` = 45857) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000193
Run Time: 0.000221
bytes_sent | 12364 |
bytes_received | 283365 |
packets_sent | 124 |
packets_received | 1078 |
protocol_overhead_in | 4312 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 210564 |
packets_sent_command | 61 |
packets_received_change_user | 98 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 517 |
proto_binary_fetched_short | 154 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 467 |
proto_binary_fetched_decimal | 31 |
proto_binary_fetched_json | 442 |
proto_binary_fetched_blob | 162 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 209110 |
