Run Time: 0.000710
Run Time: 0.000217
WHERE (`xf_thread`.`thread_id` = '47853')
Run Time: 0.000829
WHERE (`xf_post`.`thread_id` = 47853) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002670
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 11 | Using where; Using filesort |
Params: 47853
Run Time: 0.000117
Params: 0, tn
Run Time: 0.000162
Params: tn, XF\Pub\Controller\Thread, Index, valid, thread_id=47853, 1715203336, , 0, tn
Run Time: 0.000173
WHERE (`xf_session_activity`.`user_id` = 52274) AND (`xf_session_activity`.`unique_key` = '52274')
Run Time: 0.000174
WHERE (`xf_thread_reply_ban`.`thread_id` = 47853) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000220
Run Time: 0.000232
bytes_sent | 9840 |
bytes_received | 276547 |
packets_sent | 112 |
packets_received | 875 |
protocol_overhead_in | 3500 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 221768 |
packets_sent_command | 55 |
packets_received_change_user | 87 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 106 |
proto_binary_fetched_short | 192 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 507 |
proto_binary_fetched_json | 437 |
proto_binary_fetched_blob | 212 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 220362 |
