Computers and Software
Locked/Protected images will not delete in Lightroom
<blockquote data-quote="Fred Kingston_RIP" data-source="post: 713773" data-attributes="member: 10742"><p>Yes, you can... Continue to shoot as you were doing... locking and deleting... When you're all done, the only thing on the SD card should be the "locked" photos that you want... You already deleted what you didn't want. Just before you "Import" the photos, select ALL the photos on the SD card and change the Attribute. Then do the Import... Or did I miss something... </p><p></p><p>Nikon isn't doing anything other than changing a basic DOS file attribute</p></blockquote><p></p>
[QUOTE="Fred Kingston_RIP, post: 713773, member: 10742"] Yes, you can... Continue to shoot as you were doing... locking and deleting... When you're all done, the only thing on the SD card should be the "locked" photos that you want... You already deleted what you didn't want. Just before you "Import" the photos, select ALL the photos on the SD card and change the Attribute. Then do the Import... Or did I miss something... Nikon isn't doing anything other than changing a basic DOS file attribute [/QUOTE]
