Other Photography Equipment
Lens Cap & Heat questions
<blockquote data-quote="cwgrizz" data-source="post: 330851" data-attributes="member: 27017"><p>As far as the heat question goes, After having a bad experience with a film camera years ago, I like to keep things relatively cool. I had a lens that had to be repaired because the shutter leafs stuck together from some grease? that melted on them from the heat. </p><p></p><p>Pretzel, It would be great if I could keep the camera, etc. on my back, but crawling around under equipment, etc does not lend to that scenario. Ha! I'm basically looking for solutions that will allow me to have a camera available AFTER a days work while traveling home, etc.</p><p></p><p>Thanks again to all who have replied. Once I get some thermometers located, I will be doing some tests.</p></blockquote><p></p>
[QUOTE="cwgrizz, post: 330851, member: 27017"] As far as the heat question goes, After having a bad experience with a film camera years ago, I like to keep things relatively cool. I had a lens that had to be repaired because the shutter leafs stuck together from some grease? that melted on them from the heat. Pretzel, It would be great if I could keep the camera, etc. on my back, but crawling around under equipment, etc does not lend to that scenario. Ha! I'm basically looking for solutions that will allow me to have a camera available AFTER a days work while traveling home, etc. Thanks again to all who have replied. Once I get some thermometers located, I will be doing some tests. [/QUOTE]
