Run Time: 0.000687
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '43286')
Run Time: 0.000757
WHERE (`xf_post`.`thread_id` = 43286) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001870
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (704761, 704935, 705034, 705928, 705931))
Run Time: 0.000811
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 5 | Using index condition; Using filesort |
Params: 43286
Run Time: 0.000081
Params: 0,
Run Time: 0.000166
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=43286, 1716127290, , 0,
Run Time: 0.000141
WHERE (`xf_thread_reply_ban`.`thread_id` = 43286) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000195
Run Time: 0.000204
bytes_sent | 11876 |
bytes_received | 360681 |
packets_sent | 112 |
packets_received | 1040 |
protocol_overhead_in | 4160 |
protocol_overhead_out | 448 |
bytes_received_prepare_response_packet | 69392 |
bytes_received_change_user_packet | 290310 |
packets_sent_command | 55 |
packets_received_prepare_response | 856 |
packets_received_change_user | 106 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_skipped_ps | 90 |
proto_binary_fetched_bit | 447 |
proto_binary_fetched_short | 379 |
proto_binary_fetched_bigint | 1033 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 759 |
proto_binary_fetched_blob | 357 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 288061 |
