Run Time: 0.000476
Run Time: 0.000204
WHERE (`xf_thread`.`thread_id` = '28886')
Run Time: 0.000930
WHERE (`xf_post`.`thread_id` = 28886) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004344
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 22 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (418107, 418592, 444075))
Run Time: 0.001721
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 28886
Run Time: 0.000098
Params: 0, ֛
Run Time: 0.000119
Params: ֛, XF\Pub\Controller\Thread, Index, valid, thread_id=28886, 1716594358, , 0, ֛
Run Time: 0.000112
WHERE (`xf_thread_reply_ban`.`thread_id` = 28886) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000184
Run Time: 0.000170
bytes_sent | 11844 |
bytes_received | 357336 |
packets_sent | 112 |
packets_received | 1039 |
protocol_overhead_in | 4156 |
protocol_overhead_out | 448 |
bytes_received_prepare_response_packet | 69392 |
bytes_received_change_user_packet | 286965 |
packets_sent_command | 55 |
packets_received_prepare_response | 856 |
packets_received_change_user | 105 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 89 |
rows_buffered_from_client_ps | 89 |
rows_skipped_ps | 89 |
proto_binary_fetched_bit | 398 |
proto_binary_fetched_short | 371 |
proto_binary_fetched_bigint | 1016 |
proto_binary_fetched_decimal | 27 |
proto_binary_fetched_json | 754 |
proto_binary_fetched_blob | 355 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 284729 |
