Run Time: 0.000773
Run Time: 0.000239
WHERE (`xf_thread`.`thread_id` = '29717')
Run Time: 0.000826
WHERE (`xf_post`.`thread_id` = 29717) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002381
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
Params: 29717
Run Time: 0.000132
Params: 0, v؍
Run Time: 0.000170
Params: v؍, XF\Pub\Controller\Thread, Index, valid, thread_id=29717, 1717160846, , 0, v؍
Run Time: 0.000172
WHERE (`xf_session_activity`.`user_id` = 37842) AND (`xf_session_activity`.`unique_key` = '37842')
Run Time: 0.000195
WHERE (`xf_thread_reply_ban`.`thread_id` = 29717) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000226
Run Time: 0.000223
bytes_sent | 9840 |
bytes_received | 282012 |
packets_sent | 112 |
packets_received | 875 |
protocol_overhead_in | 3500 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 227233 |
packets_sent_command | 55 |
packets_received_change_user | 87 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 140 |
proto_binary_fetched_short | 189 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 500 |
proto_binary_fetched_json | 423 |
proto_binary_fetched_blob | 202 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 225839 |
