Run Time: 0.000781
Run Time: 0.000171
WHERE (`xf_thread`.`thread_id` = '23438')
Run Time: 0.000608
WHERE (`xf_post`.`thread_id` = 23438) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002128
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (317802, 317846))
Run Time: 0.000802
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 23438
Run Time: 0.000087
Params: 0,
Run Time: 0.000128
WHERE (`xf_session_activity`.`user_id` = 25730) AND (`xf_session_activity`.`unique_key` = '25730')
Run Time: 0.000179
WHERE (`xf_thread_reply_ban`.`thread_id` = 23438) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000192
Run Time: 0.000181
bytes_sent | 11918 |
bytes_received | 358651 |
packets_sent | 118 |
packets_received | 1076 |
protocol_overhead_in | 4304 |
protocol_overhead_out | 472 |
bytes_received_rset_header_packet | 369 |
bytes_received_rset_row_packet | 123 |
bytes_received_prepare_response_packet | 71491 |
bytes_received_change_user_packet | 286170 |
packets_sent_command | 58 |
packets_received_rset_header | 41 |
packets_received_rset_row | 21 |
packets_received_prepare_response | 885 |
packets_received_change_user | 108 |
result_set_queries | 18 |
non_result_set_queries | 3 |
ps_buffered_sets | 18 |
ps_prepared_once_executed | 18 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_skipped_ps | 90 |
proto_binary_fetched_bit | 498 |
proto_binary_fetched_short | 368 |
proto_binary_fetched_bigint | 997 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 686 |
proto_binary_fetched_blob | 354 |
com_stmt_prepare | 19 |
com_stmt_execute | 19 |
com_stmt_close | 18 |
bytes_received_real_data_ps | 283988 |
