Run Time: 0.000620
Run Time: 0.000204
WHERE (`xf_thread`.`thread_id` = '31088')
Run Time: 0.001236
WHERE (`xf_post`.`thread_id` = 31088) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003458
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (462534, 462557, 462747))
Run Time: 0.002004
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 12 | Using index condition; Using filesort |
Params: 31088
Run Time: 0.000119
Params: 0, vͥ
Run Time: 0.000151
Params: vͥ, XF\Pub\Controller\Thread, Index, valid, thread_id=31088, 1716121765, , 0, vͥ
Run Time: 0.000178
WHERE (`xf_session_activity`.`user_id` = 30105) AND (`xf_session_activity`.`unique_key` = '30105')
Run Time: 0.000131
WHERE (`xf_thread_reply_ban`.`thread_id` = 31088) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000173
Run Time: 0.000152
bytes_sent | 12336 |
bytes_received | 363973 |
packets_sent | 124 |
packets_received | 1096 |
protocol_overhead_in | 4384 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 291172 |
packets_sent_command | 61 |
packets_received_change_user | 116 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 98 |
rows_buffered_from_client_ps | 98 |
rows_skipped_ps | 98 |
proto_binary_fetched_bit | 978 |
proto_binary_fetched_short | 383 |
proto_binary_fetched_bigint | 1108 |
proto_binary_fetched_decimal | 36 |
proto_binary_fetched_json | 726 |
proto_binary_fetched_blob | 356 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 288808 |
