Run Time: 0.000765
Run Time: 0.000204
WHERE (`xf_thread`.`thread_id` = '24332')
Run Time: 0.000808
WHERE (`xf_post`.`thread_id` = 24332) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003085
Params: 24332
Run Time: 0.000119
Params: 0, K
Run Time: 0.000171
Params: K, XF\Pub\Controller\Thread, Index, valid, thread_id=24332, 1714310779, , 0, K
Run Time: 0.000177
WHERE (`xf_session_activity`.`user_id` = 25354) AND (`xf_session_activity`.`unique_key` = '25354')
Run Time: 0.000164
WHERE (`xf_thread_reply_ban`.`thread_id` = 24332) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000192
Run Time: 0.000201
bytes_sent | 9840 |
bytes_received | 346056 |
packets_sent | 112 |
packets_received | 885 |
protocol_overhead_in | 3540 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 291277 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 259 |
proto_binary_fetched_short | 360 |
proto_binary_fetched_bigint | 941 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 289264 |
