Nikon DSLR Cameras
D3100
Fix required for "Error. Press shutter release button again" for Nikon D3100
<blockquote data-quote="TheCROW" data-source="post: 487076" data-attributes="member: 40286"><p><strong>Re: Fix required for "Error. Press shutter release button again" for Nikon D3100</strong></p><p></p><p>This error usually means that the aperture motor has seized, or gone bad. If the camera is out of warranty you can try to un-seize it yourself by removing the bottom plate of the camera. Have a look here for how to do it, but avoid spraying the silicone lubricant inside the camera, just put a drop on a toothpick and use that to lubricate the gear IF and only IF you choose to do that.</p><p><a href="http://www.youtube.com/watch?v=rcV90NKs1ck" target="_blank">How to fix the Nikon DSLR "Press shutter release button again" error - YouTube</a></p></blockquote><p></p>
[QUOTE="TheCROW, post: 487076, member: 40286"] [b]Re: Fix required for "Error. Press shutter release button again" for Nikon D3100[/b] This error usually means that the aperture motor has seized, or gone bad. If the camera is out of warranty you can try to un-seize it yourself by removing the bottom plate of the camera. Have a look here for how to do it, but avoid spraying the silicone lubricant inside the camera, just put a drop on a toothpick and use that to lubricate the gear IF and only IF you choose to do that. [URL="http://www.youtube.com/watch?v=rcV90NKs1ck"]How to fix the Nikon DSLR "Press shutter release button again" error - YouTube[/URL] [/QUOTE]
Nikon DSLR Cameras
D3100
