Run Time: 0.000759
Run Time: 0.000249
WHERE (`xf_thread`.`thread_id` = '5846')
Run Time: 0.000858
WHERE (`xf_post`.`thread_id` = 5846) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003805
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (55443))
Run Time: 0.001557
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 3 | Using index condition; Using where |
Params: 5846
Run Time: 0.000117
Params: 0,
Run Time: 0.000156
WHERE (`xf_session_activity`.`user_id` = 9503) AND (`xf_session_activity`.`unique_key` = '9503')
Run Time: 0.000199
WHERE (`xf_thread_reply_ban`.`thread_id` = 5846) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000185
Run Time: 0.000220
bytes_sent | 11889 |
bytes_received | 354524 |
packets_sent | 118 |
packets_received | 1075 |
protocol_overhead_in | 4300 |
protocol_overhead_out | 472 |
bytes_received_rset_header_packet | 369 |
bytes_received_rset_row_packet | 123 |
bytes_received_prepare_response_packet | 71491 |
bytes_received_change_user_packet | 282043 |
packets_sent_command | 58 |
packets_received_rset_header | 41 |
packets_received_rset_row | 21 |
packets_received_prepare_response | 885 |
packets_received_change_user | 107 |
result_set_queries | 18 |
non_result_set_queries | 3 |
ps_buffered_sets | 18 |
ps_prepared_once_executed | 18 |
rows_fetched_from_server_ps | 89 |
rows_buffered_from_client_ps | 89 |
rows_skipped_ps | 89 |
proto_binary_fetched_bit | 440 |
proto_binary_fetched_short | 365 |
proto_binary_fetched_bigint | 982 |
proto_binary_fetched_decimal | 27 |
proto_binary_fetched_json | 682 |
com_stmt_prepare | 19 |
com_stmt_execute | 19 |
com_stmt_close | 18 |
bytes_received_real_data_ps | 279898 |
