Run Time: 0.000728
Run Time: 0.000206
WHERE (`xf_thread`.`thread_id` = '21298')
Run Time: 0.000808
WHERE (`xf_post`.`thread_id` = 21298) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003866
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 16 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (279924))
Run Time: 0.001262
Params: 21298
Run Time: 0.000087
Params: 0, v6
Run Time: 0.000170
Params: v6, XF\Pub\Controller\Thread, Index, valid, thread_id=21298, 1717015340, , 0, v6
Run Time: 0.000148
WHERE (`xf_session_activity`.`user_id` = 14451) AND (`xf_session_activity`.`unique_key` = '14451')
Run Time: 0.000189
WHERE (`xf_thread_reply_ban`.`thread_id` = 21298) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000239
Run Time: 0.000209
bytes_sent | 12304 |
bytes_received | 332293 |
packets_sent | 124 |
packets_received | 1081 |
protocol_overhead_in | 4324 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 259492 |
packets_sent_command | 61 |
packets_received_change_user | 101 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 83 |
rows_buffered_from_client_ps | 83 |
rows_skipped_ps | 83 |
proto_binary_fetched_bit | 271 |
proto_binary_fetched_short | 293 |
proto_binary_fetched_int24 | 119 |
proto_binary_fetched_bigint | 778 |
proto_binary_fetched_json | 593 |
proto_binary_fetched_blob | 293 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 257626 |
