Run Time: 0.000704
Run Time: 0.000216
WHERE (`xf_thread`.`thread_id` = '35250')
Run Time: 0.000810
WHERE (`xf_post`.`thread_id` = 35250) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004617
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (532929, 533014, 533032, 534115))
Run Time: 0.001303
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 6 | Using index condition; Using filesort |
Params: 35250
Run Time: 0.000096
Params: 0,
Run Time: 0.000145
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=35250, 1716317138, , 0,
Run Time: 0.000095
WHERE (`xf_session_activity`.`user_id` = 41442) AND (`xf_session_activity`.`unique_key` = '41442')
Run Time: 0.000230
WHERE (`xf_thread_reply_ban`.`thread_id` = 35250) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000234
Run Time: 0.000231
bytes_sent | 12365 |
bytes_received | 369457 |
packets_sent | 124 |
packets_received | 1089 |
protocol_overhead_in | 4356 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 296697 |
packets_sent_command | 61 |
packets_received_change_user | 109 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 91 |
rows_buffered_from_client_ps | 91 |
rows_skipped_ps | 91 |
proto_binary_fetched_bit | 621 |
proto_binary_fetched_short | 371 |
proto_binary_fetched_bigint | 1023 |
proto_binary_fetched_decimal | 30 |
proto_binary_fetched_json | 696 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 294496 |
