Run Time: 0.000497
Run Time: 0.000203
WHERE (`xf_thread`.`thread_id` = '29162')
Run Time: 0.000972
WHERE (`xf_post`.`thread_id` = 29162) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001896
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
Params: 29162
Run Time: 0.000070
Params: 0, t
Run Time: 0.000118
Params: t, XF\Pub\Controller\Thread, Index, valid, thread_id=29162, 1715918112, , 0, t
Run Time: 0.000104
WHERE (`xf_session_activity`.`user_id` = 37727) AND (`xf_session_activity`.`unique_key` = '37727')
Run Time: 0.000148
WHERE (`xf_thread_reply_ban`.`thread_id` = 29162) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000154
Run Time: 0.000153
bytes_sent | 9840 |
bytes_received | 259863 |
packets_sent | 112 |
packets_received | 872 |
protocol_overhead_in | 3488 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 205084 |
packets_sent_command | 55 |
packets_received_change_user | 84 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 68 |
rows_buffered_from_client_ps | 68 |
rows_skipped_ps | 68 |
proto_binary_fetched_bit | 104 |
proto_binary_fetched_short | 138 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 368 |
proto_binary_fetched_json | 363 |
proto_binary_fetched_blob | 157 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 203885 |
