Run Time: 0.000669
Run Time: 0.000221
WHERE (`xf_thread`.`thread_id` = '34780')
Run Time: 0.000784
WHERE (`xf_post`.`thread_id` = 34780) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003633
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (522671, 522673, 522675, 522676, 522678, 522679, 522680, 522692, 522962, 523307, 523653, 523955))
Run Time: 0.002628
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 27 | Using index condition; Using filesort |
Params: 34780
Run Time: 0.000084
Params: 0,
Run Time: 0.000161
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=34780, 1715226650, , 0,
Run Time: 0.000130
WHERE (`xf_session_activity`.`user_id` = 34269) AND (`xf_session_activity`.`unique_key` = '34269')
Run Time: 0.000240
WHERE (`xf_thread_reply_ban`.`thread_id` = 34780) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000232
Run Time: 0.000239
bytes_sent | 12480 |
bytes_received | 381623 |
packets_sent | 124 |
packets_received | 1111 |
protocol_overhead_in | 4444 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 308822 |
packets_sent_command | 61 |
packets_received_change_user | 131 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 113 |
rows_buffered_from_client_ps | 113 |
rows_skipped_ps | 113 |
proto_binary_fetched_bit | 1850 |
proto_binary_fetched_short | 431 |
proto_binary_fetched_bigint | 1318 |
proto_binary_fetched_decimal | 51 |
proto_binary_fetched_json | 801 |
proto_binary_fetched_blob | 366 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 306131 |
