Run Time: 0.000517
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '484')
Run Time: 0.001133
WHERE (`xf_post`.`thread_id` = 484) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001471
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 4 | Using where; Using filesort |
Params: 484
Run Time: 0.000084
Params: 0, ه
Run Time: 0.000166
Params: ه, XF\Pub\Controller\Thread, Index, valid, thread_id=484, 1716225584, , 0, ه
Run Time: 0.000154
WHERE (`xf_session_activity`.`user_id` = 27) AND (`xf_session_activity`.`unique_key` = '27')
Run Time: 0.000202
WHERE (`xf_thread_reply_ban`.`thread_id` = 484) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000229
Run Time: 0.000217
bytes_sent | 9812 |
bytes_received | 244067 |
packets_sent | 112 |
packets_received | 869 |
protocol_overhead_in | 3476 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 189288 |
packets_sent_command | 55 |
packets_received_change_user | 81 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 65 |
rows_buffered_from_client_ps | 65 |
rows_skipped_ps | 65 |
proto_binary_fetched_bit | 68 |
proto_binary_fetched_short | 87 |
proto_binary_fetched_int24 | 35 |
proto_binary_fetched_bigint | 236 |
proto_binary_fetched_json | 303 |
proto_binary_fetched_blob | 112 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 188266 |
