Run Time: 0.000654
Run Time: 0.000262
WHERE (`xf_thread`.`thread_id` = '28514')
Run Time: 0.001164
WHERE (`xf_post`.`thread_id` = 28514) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004153
Params: 28514
Run Time: 0.000146
Params: 0,
Run Time: 0.000150
WHERE (`xf_session_activity`.`user_id` = 24646) AND (`xf_session_activity`.`unique_key` = '24646')
Run Time: 0.000164
WHERE (`xf_thread_reply_ban`.`thread_id` = 28514) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000207
Run Time: 0.000223
bytes_sent | 9438 |
bytes_received | 302606 |
packets_sent | 106 |
packets_received | 868 |
protocol_overhead_in | 3472 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 248147 |
packets_sent_command | 52 |
packets_received_change_user | 92 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 76 |
rows_buffered_from_client_ps | 76 |
rows_skipped_ps | 76 |
proto_binary_fetched_bit | 200 |
proto_binary_fetched_short | 274 |
proto_binary_fetched_bigint | 720 |
proto_binary_fetched_json | 523 |
proto_binary_fetched_blob | 277 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 246482 |
