Run Time: 0.000513
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '8595')
Run Time: 0.000783
WHERE (`xf_post`.`thread_id` = 8595) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004198
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
Params: 8595
Run Time: 0.000097
Params: 0, t4
Run Time: 0.000188
Params: t4, XF\Pub\Controller\Thread, Index, valid, thread_id=8595, 1716220110, , 0, t4
Run Time: 0.000134
WHERE (`xf_session_activity`.`user_id` = 9521) AND (`xf_session_activity`.`unique_key` = '9521')
Run Time: 0.000213
WHERE (`xf_thread_reply_ban`.`thread_id` = 8595) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000287
Run Time: 0.000225
bytes_sent | 9828 |
bytes_received | 338778 |
packets_sent | 112 |
packets_received | 885 |
protocol_overhead_in | 3540 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 283999 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 261 |
proto_binary_fetched_short | 359 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 282016 |
