Nikon DSLR Cameras
D5100
D5100 Vello BG-N6 battery grip.
<blockquote data-quote="Blurrymess" data-source="post: 49799" data-attributes="member: 9022"><p>You're welcome, Patrick. I failed to mention that the grip has a slot where you can store the camera battery door (as you have to remove it to install the grip, just like all the other grips). Also, there is a spring action pin behind the battery grip door, which stops the battery door from rattling around (I believe this is only on this grip). The thing to be aware of is the protruding tightening wheel, and the set back shutter release, to consider if this would be compatible with the way you like to grip.</p></blockquote><p></p>
[QUOTE="Blurrymess, post: 49799, member: 9022"] You're welcome, Patrick. I failed to mention that the grip has a slot where you can store the camera battery door (as you have to remove it to install the grip, just like all the other grips). Also, there is a spring action pin behind the battery grip door, which stops the battery door from rattling around (I believe this is only on this grip). The thing to be aware of is the protruding tightening wheel, and the set back shutter release, to consider if this would be compatible with the way you like to grip. [/QUOTE]
Nikon DSLR Cameras
D5100
