Run Time: 0.000834
Run Time: 0.000212
WHERE (`xf_thread`.`thread_id` = '45460')
Run Time: 0.000814
WHERE (`xf_post`.`thread_id` = 45460) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 20) AND (`xf_post`.`position` < 40)
Run Time: 0.002522
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 7 | Using index condition; Using where; Using filesort |
Params: 45460
Run Time: 0.000095
Params: 0, z
Run Time: 0.000214
Params: z, XF\Pub\Controller\Thread, Index, valid, thread_id=45460&page=2, 1716197493, , 0, z
Run Time: 0.000168
WHERE (`xf_session_activity`.`user_id` = 13196) AND (`xf_session_activity`.`unique_key` = '13196')
Run Time: 0.000184
WHERE (`xf_thread_reply_ban`.`thread_id` = 45460) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000203
Run Time: 0.000182
bytes_sent | 9849 |
bytes_received | 258513 |
packets_sent | 112 |
packets_received | 871 |
protocol_overhead_in | 3484 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 203734 |
packets_sent_command | 55 |
packets_received_change_user | 83 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 67 |
rows_buffered_from_client_ps | 67 |
rows_skipped_ps | 67 |
proto_binary_fetched_bit | 90 |
proto_binary_fetched_short | 122 |
proto_binary_fetched_int24 | 49 |
proto_binary_fetched_bigint | 326 |
proto_binary_fetched_json | 342 |
proto_binary_fetched_blob | 142 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 202577 |
